Previous in Forum: droop   Next in Forum: Ultimate Short Circuit Breaking Capacity
The Stabiloy Cable
04/01/2010 11:15 PM
Can anyone tell me some information of stabiloy cable?Thanks!
If you use it instead of YJV cable,what problem will you meet?
Re: the stabiloy cable
04/01/2010 11:53 PM
We have switched to Stabiloy cable for our low voltage runs and it works great and is a lot less work involved, see the following;
STABILOY® aluminum alloy feeders and metal clad (MC) aluminum alloy feeder cables provide superior value and quality to the electrical contractor. This enables building owners to realign building construction costs to create the sustainable and energy efficient structures of tomorrow.
STABILOY feeders:
  • Highly engineered electrical solutions that provide superior connection reliability and unsurpassed quality
  • Offer electrical contractors twice the ampacity per pound serviced as copper
  • Lightweight and flexible with 40% less spring back making STABILOY aluminum alloy feeder cables easier to work with than similar ampacity copper conductors
STABILOY MC Feeders:
  • Eliminate the need for multiple reels and paralleling
  • Eliminate conduit pulls and lube requirements
  • Add phase identification for safe and accurate connections
  • Reduce labor time 66% over single conductor installations in steel conduit
  • Allow contractors to focus on the electrical connections and not pipe assembly
It should meet any requirements you have to have on any job.
jhunter
jhunter1972
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
