Previous in Forum: Soak Pits   Next in Forum: Sealing Around Tank Bottom
Horizontal Displacement of Dome Ring Beam
04/02/2010 12:13 PM
If the horizontal displacement of a steel reinforced dome ring beam is a function of 1/E, could you make a case for the E of the composite beam (Ecomp) being found thus: As * Es + Ac * Ec = Acomp * Ecomp, where As = Area of steel, Es = Modulus of Elasticity of steel, etc.?
Good Answers: 114
Re: Horizontal displacement of dome ring beam.
04/02/2010 5:26 PM
No. If the ring beam is in tension, you disregard the concrete, it is almost certainly cracked and useless in tension. If it is in compression, both materials will be strained by the same amount. Since Es is greater than Ec, the area of steel is multiplied by the ratio to obtain a transformed area. Transformed Ac= Ac + As*Es/Ec.
