Hi All,
I am working in a company manufacturing brass cable glands and terminals (neutral links). I came across a specific requirement of M6 Steel Screws from Mild Steel Grade 5.8
From the internet, I knew that 5 stands for the Tensile Ultimate Strength (UTS) in MPa divided by 100. The digit after the decimal .8 stands for its Tensile Yield Strength which is 0.8 times to its UTS.
i.e. A screw of 5.8 Steel Grade means 500MPa is Tensile Ultimate Strength and 0.8 x 500 = 400MPa is the Tensile Yield Strength.
Kindly correct me if I am wrong here.
Now my question is how to check these 500MPa UTS and 400MPa Yield Strength?? Is it something the raw material supplier has to certify?? Also which grade of steel should be used? On the internet, I could only find it mentioning as low carbon steel, but it do not specify for a particular grade of steel. Is it possible to achieve 5.8 Grade in any low carbon steel???
Also these M6 Screws are made on cold forming presses, generating lot of stresses. Only the heads are made and the threads are later made by thread rolling.
If so, will the UTS and YS be effected? If yes, how to measure it.
Sorry for long question, but would appreciate your reply.
Regards
JACOB
