Previous in Forum: Nameplate data of distribution Recloser   Next in Forum: how to check the maximum output power of battery
battery charging with alternator
04/03/2010 1:00 PM
i want 2 charge a 3 car battery...with the help of a 2 alternator...
then how can i connect each battery n each alternator...
n yaa...tell me what will happen when i m connecting battery in series n in parallel when i m charging them..
and the same thing for alternator...
what will happen when i connect them in series n what wil happen in series...
is which condition of alternator we can generate maximun power..
n in which condition of battery we can charge them vary fast..
Re: battery charging with alternator
04/03/2010 1:29 PM
I'll pass on this one.
04/03/2010 2:26 PM
There is a very good reason that any shortcuts in technical writing should be avoided. I have no idea what your question is. More accurately, I have too many ideas about what your might be. Unfortunately for you all of my ideas tell me that you know almost nothing about batteries and charging circuits.
Good Answers: 60
04/03/2010 3:56 PM
Could you put question in english please as it makes no sense.
ps dont use abbreviations cos that makes it worse.
now try again please
what is a 3 car battery
what is a 2 alternator
if you connect batteries in series and connect them to a 12 volt alternator it will melt
Good Answers: 141
04/03/2010 7:01 PM
If I have broken your code well, you have received a "third battery" for Easter?
Congratulations!
You are a professional battery charger with already 2 batteries and with on each battery a alternator as charger?
The fastest way to charge the batteries is to connect these all in parallel - and make the alternators spin. I hope you have these connected to a motor.
But if not, you can spin one with your left hand and the other with your right hand. The faster you turn, the faster you charge.
Or make someone else do it for you?
Plenty of room here
dvmdsc (1); lyn (1); peterg7lyq (1); redfred (1)
