Previous in Forum: Motor Convert 200v to 380   Next in Forum: Drive shaft design book
Technical Personnel for Hydroelectric Power Plants
04/09/2010 6:47 PM
Hello everybody:
I know for experience that hydroelectric power plants are complex electrical and mechanical installations, which need trained personnel for Operation and Maintenance.
Sufficient number of qualified personnel are not always available to meet the plant requirements, and this necessitates a training program to develop trainees to perform well at journeyman level.
According to the power (capacity of the plant) installed, I wonder if exists "a rule of thumbs" or somebody knows for sure the approximate number of technicians (Trainees) to be employed to attend the Training Program.
And finally, but not less important, during normal operation of the power plant, how many technicians are usually considered the proper number for operation and maintenance labors?
Your comments are appreciated. Thanks.
Re: Technical Personnel for Hydroelectric Power Plants
04/11/2010 12:04 AM
The capacity of the plant, the capacity of the plant versus the grid stability, the degree of plant automation and remote control, the dam operation, can the dam gates be remotely controlled, spillway capacity, all contribute to determine the staffing levels at any time.
If a plant is small (less then 10MW) in comparision to the grid, automated and does not have trash build-up then a daily operator check of plant and trash racks may be adequate. During bad weather, spring run-off, ice, leaves, trash handling or for environmental monitoring may require one or two operators. The location of the power plant, proximity to operations staff or if remotely dispatched operator call-in response time. The dam criticality, flash flood potential, response time of operators all get into creating an answer.
Twenty years ago, I've seen 60MW plants that were controlled remotely, with an operator on site during at least part of the day to clean-up, clean trash racks and monitor for efficient production and any environmental testing, as above extraordinary conditions requires more operators.
At some MW the lost revenue during an outage call-in and the lack of automation will justify full time operator(s). Today it is still less expensive to put in sensing and automation, more cameras and communications then an operator.
Mechanical or Electrical Maintenance staff are typically not on-site, but roving to plant outages for repairs on a scheduled basis and at other plants for emergency repairs.
"I believe we are masters of our lives - we hold all the cards and it is up to us to use them right." Vesna Vulova - survived 33,000ft fall
04/13/2010 8:28 AM
Hello everybody:
CoronaCameraMan, thanks for your valuable comments.
Register to Reply 2 comments
