Previous in Forum: Small Electric Motor   Next in Forum: Difference Between "FM200" and "NAF s125" GAS for Fire Suppression
DC water pumps for artesian well about 120 feet deep
04/09/2010 7:33 PM
What are my best alternatives to installing this type of pump for my water supply?
Pathfinder Tags: DC WATER PUMPS
Good Answers: 58
Re: DC water pumps for artesian well about 120 feet deep
04/09/2010 9:14 PM
We need more specs. How far down is the water? I thought artesian wells had pressure. I'm not sure dc water pumps are all that available. For deep wells, I prefer a surface pump with a deep well adapter. Having the pump down the well is more trouble.
mike k
04/09/2010 9:26 PM
The pressure from the artesian well is insufficient to provide water for the entire household so additional pressure is required. I will also have a holding tank of approximately 20 gallons. How would a surface pump work? Thanks
Good Answers: 58
04/09/2010 9:38 PM
If you're getting water all the way to the house, all you need is a booster pump. If you really insist on dc, look into pumps for boats. Otherwise, a regular house pump will do.
mike k
04/09/2010 9:15 PM
I thought the term Artesian well ment self flowing well?
Register to Reply 4 comments
chanrich (1); mike k (2); tcmtech (1)
