Previous in Forum: Air line design   Next in Forum: Backside Welding
Safe Location of Fired Heater in a Oil Terminal
04/12/2010 7:14 AM
Please let me know what is the safe distance that need to be maintained from class I and Class II product storage tank to the hot oil system used to heat fuel oil tanks. I had refered to NFPA 30, 31 etc,. to find, still i am not sucessful. I need this data to decide the plot plan of the oil terminal.
Good Answers: 61
Re: Safe Location of Fired Heater in a Oil Terminal
04/12/2010 11:48 AM
I think it depends on whether the "Heater" if fired or steam heated.
If you have a Flame Fired Heater involved then it should be located up wind and a minimum of 60 meters away from any source of flammable vapors.
If no flame involved then it does not mater where you located it. However, I would locate the heater outside of the dike (spill retention area).
Do it once and do it right
Reply to Forum Thread
