Previous in Forum: Stand Alone Unit Control Panel (UCP) Location   Next in Forum: Differential pressure transmitter
Pressure Safety Valve
04/15/2010 4:34 AM
In PSV, there are pop up pressure and reset pressure. Please tell me, what that really means and what role does it play with the set point value .
Good Answers: 27
Re: Pressure Safety Valve
04/15/2010 5:12 AM
The PSV "pops" at the CST (Cold Set Pressure) on the test stand. It will then reset at a predetermined pressure that is lower than this "pop" set pressure. The reset pressure does not affect the set pressure as it is adjusted by setting of the notch rings which govern the secondary lift area that governs at what pressure the valve will close again after having lifted.
I have no special talent. I am only passionately curious. Albert E
Good Answers: 60
04/15/2010 5:33 PM
what does PSV stand for ? passenger service vehicles ?
if so there are unloader valves on the compressors that blow of when a set pressure is reached, reason its cheaper to dump the excess air pressure than to have a compressor that stops compressing when the pressure is reached
Good Answers: 27
04/16/2010 6:24 AM
Read the title - all will be revealed
Good Answers: 60
04/16/2010 1:57 PM
ah ha these new glasses cant read properly yet
Register to Reply 4 comments
