Previous in Forum: Interference Fit for Plastics   Next in Forum: solid flow feeder
Polyethylene Welding
04/15/2010 2:14 PM
My company makes marine hulls using Polyethylene sheet material .
We use big sheets - 8' x 4' , 1/4" thick.
We need to know if ther is a hand-held electric wire element plastic welding tool
that would melt join these sheets edge-to-edge .
Venture Hulls Canada
venture1
Pathfinder Tags: Plastic Weld
Re: Polyethylene Welding
04/15/2010 2:55 PM
The most common method is to use an electric/hot air gun and plastic filler rod. Bevel the edges to accept the rod. Then shave off any excess.
We used to make chem etchers this way.
Melting the two edges and then pressing the sheets together can be accomplished, but hand welding is more common. You'd need a full width heating element that is teflon coated to prevent the melted plastic from sticking.
Search for "plastic welders".
04/15/2010 3:29 PM
Thank you for your reply - Do you know of any manufacturers of such a tool?
venture1
04/15/2010 3:35 PM
  • Wegener Welding | Home ... full range of specialty plastic welding machines, pipe butt welders, foam welders, ... plastic pipe saws, plastic pipe band saws, plastic pipe butt welders.
    www.wegenerwelding.com/
  • Themoplastic Sheet Butt Fusion: Plastic Distributor & Fabricator Plastic Piping Systems & Solvent Cementing ... in particular, spells out in detail the requirements for butt welding machines for both piping and sheet. ...
    www.plasticsmag.com/features.asp?fIssue=Mar/Apr-07
  • Plastic Welding: Plastic Distributor & Fabricator There is a suitable solution for virtually all plastic welding requirements. .... hand held plastic extruders by Dohle, Widos Pipe butt welders and Ingenia ...
    www.plasticsmag.com/features.asp?fIssue=Mar/Apr-03
  • Butt Welding Machine :B2BManufactures.Com For Taiwan and China ... Qingdao Yidian Plastic Welding Equipment Co., Ltd. : Butt Welding Machine. Manufacturer of plastic containers, plastic extruding Welding machines, ...
    www.manufacturers.com.tw/.../Butt-Welding-Machines.html
  • BPWE Plastic Butt Welder Model SW | Plastic Sheet Butt Welding ... BPWE Plastic Butt Welder Model SW. ... Home :: Plastic Sheet Butt Welding Machines :: BPWE Plastic Butt Welder Model SW ...
    www.plasticweldingequipment.co.uk/bpwe-plastic-butt-welder-model-sw-pr-16268.html
  • Butt Welding Machines Manufacturers On B2BChinaSources.Com from ... Qingdao Yidian Plastic Welding Equipment Co., Ltd. - Butt Welding Machines. Manufacturer of plastic containers, plastic extruding welding machines, ...
    www.b2bchinasources.com ›
  • Butt Welders - Butt Welders and more
  • Amazing what you can find if you search.
04/15/2010 3:43 PM
You're hired.
venture1
Good Answers: 60
04/15/2010 5:38 PM
lyn (2); peterg7lyq (1); venture 1 (2)
