Previous in Forum: gear geometry   Next in Forum: Drive Shaft Issues
11 comments
Problem With a 1989 Celebrity
04/16/2010 4:00 PM
whitish gray smoke started coming out the exhaust when i was driving to school
when i stopped the car would shake more then usual. the exhaust would by smoky when i started to move from a stopped position.
at school when i stopped i looked under the hood and the anti freeze was draining and bubbling up into the reservoir, was not leaking out of the car.
then when i left school and drove home there was no more smoke coming out the exhaust but half way home the temp. light went on and off a couple of times then stayed on. i open the hood at home and the engine was smoking. the smoke was coming out right of the alternator by the second to the right spark plug.
could you please help me out and tell my what the problem may be and any solutions you may know of or how to fix.
the world is what you take from it, so take it all!
Re: problem with a 1989 celebrity
04/16/2010 4:13 PM
This sounds like a blown head gasket. I hope for your sake it is a blown head gasket instead of a cracked block or head. With a twenty one year old machine, a blown head gasket would not be unrealistic. While a partial engine tear-down to replace the head gasket is certainly not an insurmountable job for a home mechanic, the question you will have to answer is will this repair be worth it on a 1989 Celebrity.
Good Answers: 60
04/16/2010 5:58 PM
i concur with redfred it sounds like the head gasket, take a look at the oil dipstick see if it has whitish sludge if not water could cross over into cylinders and be burnt or gases could blow across into water jacket, causing water to be blown out.
check water in radiator is it just water or is there sludge in there
check oil is it just oil or is it a sludge
04/16/2010 4:30 PM
"there was no more smoke coming out the exhaust", because there was no more water in the radiator.
The smoke under the hood at home was probably from the overheated oil in the engine.
redfred is right. There's never a good time to buy a new car, but I think you should start shopping.
Re: Problem With a 1989 Celebrity
04/17/2010 6:32 AM
Not knowing what engine you have, Yes it could be a blown head gasket. But, before jumping to conclusions you might try this. Fill the cooling system and pressure test to see if you may have an external leak which could have leaked over the spark plug itself. This would be enough to cause it to miss and run rough, again, how rough would depend on how many cylinders the engine has. The fact that the engine overheated and continued to be driven is not good and could have done internal damage ie., head gasket,etc., A small thing such as a stuck closed thermostat could have been responsible for the whole thing. There are a few more considerations to consider,but since the engine was boiling over into the recovery bottle means it got pretty hot and therefore that overheat lite came on and stayed on. It is still worth a try to pin down the exact cause and go from there. Also, don't overlook the possibility the electric cooling fan may not be working.
Good Answers: 60
04/17/2010 7:25 AM
stuck thermostat would not cause white smoke. just overheating
i agree that a presure test of radiatior should be done
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
04/17/2010 8:29 AM
Yes, like the other respondents, you should start with a coolant system pressure test.
I would also consider a cylinder leakdown test. This may locate a blown head gasket (if it's blown from cylinder into water jacket) or cracked block/head.
Frankly, it does not sound good, based on your information. Let us know what you find.
Speak softly and carry a big stick.
04/17/2010 10:02 AM
Thanks, Peter, it would be a shame to get into a head gasket job put it all together and wind up with the same problem. Before attempting to correct the result, possible head gasket, cracked head etc., the cause of the problem needs to be found and corrected or like pregnancy, it will have a tendency to reocurr.
04/18/2010 6:01 AM
Once you found the reason for the overheating and that the head gasket is blown the head might be warped, make sure that the overhead camshaft turns freely, if not, have the head pressed back or do it yourself until the camshaft turns freely before having the head skimmed and pressure tested for cracks. If you don't you might end up with a broken camshaft. Remember to clean the head bolt holes with a thread tap.
Good Answers: 50
04/18/2010 12:15 PM
Yes, which engine do you have?
04/19/2010 4:59 PM
thx all, yes it is indeed a blown head gasket. i decide to let the car RIP. i got a 1986 Celebrity i am working on now that is in pretty good shape.
Register to Reply 11 comments
Anonymous Poster (2); Ice-Man (1); jurie sa (1); lyn (1); peterg7lyq (3); redfred (1); standarded (2)
You might be interested in: Fume Hoods, Air Velocity Flow Sensors
