Previous in Forum: Patenting Green Technology in the U.S.   Next in Forum: Low Iron Glass - Double Glaze for Greenhouse
11 comments
Winter Cooling
04/18/2010 4:27 PM
Hello, I am looking into a project that would allow me to use the winter air to cool the cooler space at my DC. and I am wondering if anyone else has completed a project like this?
Re: Winter cooling
04/18/2010 4:34 PM
What are you talking about?
Good Answers: 60
Re: Winter Cooling
04/18/2010 5:47 PM
what prey is a DC in the questions context ?
Good Answers: 141
Re: Winter Cooling
04/18/2010 7:53 PM
Is DC - drained cells - don't use the air. Put snow or ice on it, without bag.
Plenty of room here
Reply Off Topic (Score 4)
Re: Winter Cooling
04/18/2010 8:04 PM
How can this be off topic when no one knows what the topic is?
Good Answers: 141
Re: Winter Cooling
04/18/2010 8:44 PM
I wonder if posters who live with DC, in a DC or even have one can be taken serious.
Plenty of room here
Good Answers: 119
Re: Winter Cooling
04/19/2010 1:55 PM
What is DC?
If I understand your question correctly, you want to bring in winter air to keep a cold box... cold.
Simply circulating the outside cold air into the box should be more efficient than running a refrigeration pump. I thought about doing this a few years ago for a 50 cubic ft beverage cooler. My idea used 2 insulated PVC plumbing pipes (cheap), a small computer fan, 2 temperature sensors and a simple logic circuit to form a thermostat.
If outside air is below set-point AND cold-box air is above set-point, then fan=ON.
If outside air is above set-point AND cold-box air is above set-point, then compressor=ON (or Peltier device=ON).
If cold-box air is below set-point, all devices=OFF.
(of course a hysteresis window of a few degrees and a compressor lockout timer would be present)
I never got past the planning stage. There were 2 main reasons why it would not work for my project.
#1) I still needed a refrigeration compressor or Peltier device during 9 months of the year and energy cost savings for only 3 months was minimal.
#2) Running cumbersome air circulation lines to anything other than a dedicated walk-in cooler was just impractical.
Suggest you think it through carefully before spending time and money on something which may not be practical.
Re: Winter Cooling
04/19/2010 2:28 PM
DC= Distribution center,
The main idea is to use the winter air to cool product in stead of a 400hp screw compressor which uses alot of energy ...
Keep in mind that I am located in canada where it is below freezing for 4 months of the year.
Re: Winter Cooling
04/19/2010 2:37 PM
Why didn't you say so? And how can we keep in mind that you are in Canada since you never bothered to tell us.
You still haven't given enough information for a useful answer.
Like, how much volume/temp difference throughout the year/Percentage of volume in use over time, etc. etc. etc.
Good Answers: 119
Re: Winter Cooling
04/19/2010 2:54 PM
A cold air system similar to my suggestion above (except scaled up ) could probably be installed at a moderate cost. If properly controlled, it might help reduce energy costs. Difficult to estimate install cost or energy savings without detailed site construction plans and seasonal weather details. Suggest you consult a qualified HVAC Engineer for best estimates.
Good Answers: 60
Re: Winter Cooling
04/20/2010 7:12 AM
next time you post a question why not put all the information.
size of room. where its located where your located etc try to think ? if you was asked the same question from a complete stranger what information would you need to come up with a good response
Good Answers: 101
Re: Winter Cooling
04/23/2010 1:26 PM
Hot air rises, cold air sinks. Try installing an insulated stack to allow the warm air from your, what was it you said, dead cabbage was it? to rise out of the building. The insulation will prevent the frigid surroundings from cooling the air in the stack to such an extent that the system won't work. Cooler air will naturally flow in from somewhere else,so if you have a duct or something similar connected to the outside, icy cold air will be drawn in to take its place.
By the way, what's the temperature that you need your dead cabbage at? If it's above 0oC, you'll need something to raise it to the required temperature as well.
P.S. Why not simply throw away your rotting cabbage instead of trying to keep it cool? I'm sure it must stink something awful.
Anonymous Poster (1); DVader1000 (1); dvmdsc (2); lyn (3); mjb1962853 (2); peterg7lyq (2)
