Previous in Forum: ASTM, IS Standards Free downloads related   Next in Forum: Wet CO2 want stainless steel material?
Determine S.S.U. at Different Temps.
04/19/2010 2:49 AM
Determine the viscosity of an oil at 70C if it has a viscosity of 250 S.S.U. at 37.8C and 50 S.S.U. at 99C.
Having a little trouble with the equation.
Thanks in advance.
CR
Good Answers: 27
Re: Determine S.S.U. at different temps.
04/19/2010 4:42 AM
Which equation? Draw a straight line between the two points and you will not be terribly far out, but much better, just get the oil data sheet from the oil company (web site should do) with the curve already drawn for you.
I have no special talent. I am only passionately curious. Albert E
04/19/2010 5:44 AM
Looks like homework to me. The LOP didn't even bother to alter the question, just copied it from the book/test.
Good Answers: 183
04/19/2010 10:51 AM
Viscosity is NOT a linear function of temperature!
04/21/2010 3:01 AM
Usually, when the common log of viscosity is plotted against the inverse of Kelvin temperature it will form a double curved line (similar to the pH curve from titrating a strong acid with a strong base). There is a range of moderate temperatures where the logs of viscosity will be essentially linear and inversely proportional to the temperature (K). Although some variables (such as molecular weight) may be good predictors, empirical values of viscosity usually need to be determined for each substance (some are listed in handbooks).
04/19/2010 6:11 AM
Good Answers: 60
Re: Determine S.S.U. at Different Temps.
04/20/2010 7:14 AM
what is the grade of oil ie 20/50 10/40 etc
Anonymous Poster (1); Kaisan (1); lyn (1); nick name (1); okiescienceprof (1); peterg7lyq (1)
