Previous in Forum: Adhesive used for Windshield Mounting   Next in Forum: Car Body
19 comments
Single Barrel Carburetor Problems On Antique
04/21/2010 7:12 AM
Engine starts easy, during warm up has good idle with a little choke on, once temperature is up to normal, idle comes up on its own after manual choke is off
Driving is good with good acceleration but when you stop vehicle with clutch in the rpms drop and it wants to stall, slight tap of the gas the RPM's come back up and slightly races.
When in idle mode at above normal rpm's slightly touching the throttle body linkage the engine rpm drops off fast and it wants to stall.
Any ideas before I remove and rebuild????????
Good Answers: 266
Re: Single Barrel Carburetor Problems On Antique
04/21/2010 7:37 AM
How about make model and date of manufacture my crystal ball is broke.
04/21/2010 7:43 AM
1948 ford F1 226 engine, holly carb. no numbers
Good Answers: 60
Re: single Barrel Carburetor Problems On Antique
04/21/2010 7:51 AM
Good Answers: 60
04/21/2010 7:44 AM
Your butterfly valve/flap is sticking.
you cannot set the tickover because the spindel/flap is sticking.
strip and clean shaft when you put butterfly back on dont tighten screws until the flap is push past the normal tick over point so its central then tighten screws and make sure it doesnt stick in throttle tube.
also a stronger return spring may help.
on some carbs there is an air bypass tube to allow air past butterfly for tick over this if fitted may be blocked.
hope this helps
http://hudsonterraplane.com/tech/1934/1934CarburetorTech.pdf
http://www.motorera.com/dictionary/CA.HTM
http://www.youtube.com/watch?v=i0jgvYkzLDc
the idle mixture screw here also allows air past the throttle this is used for tick over control as the air is restricted with the throttle flap shut this may be blocked remove screw and blow out DO NO USE TO MUCH PRESURE MAXIMUM I WOULD SUGGEST ABOUT 30 PSI
http://www.chevyhiperformance.com/techarticles/83118_carburetor_basics/index.html
04/21/2010 8:07 AM
thanks much the old 48 will appreciate the work
04/21/2010 9:20 AM
A vacuum leak can cause erratic idle.
Use a section of hose to look for the leak by sound.
Everything I know about opera I learned from Bugs Bunny
04/21/2010 12:19 PM
I had a 1948 Ford not so long ago. Six volt system , flathead , I didn't have the
gearbox , and I put it up for sale , but , as I recall , parts are virtually unobtainable ,
and ignition parts especially.
Steele m a
04/22/2010 6:54 AM
I just totaly rebuilt the entire brake system all parts are available from Dennis carpenter, LMC Macs auto parts, and several others.
Carb. does not have vacuum leak, bottom throttle plate and shaft are worn, carbureater USA is going to rebuid and replace throttle shaft.
Also just redid the entire starting and ignition system also all parts are available with no problems the truck starts great!!!!
04/21/2010 11:11 PM
I agree to look for a vacuum leak around gaskets between carb & manifold. Older engines on occasion develop this problem. I had this problem about 33 years ago.
Good Answers: 56
04/21/2010 11:44 PM
"I agree to look for a vacuum leak"
The fastest most reliable method I have ever used for finding vacuum leaks was a basting bulb filled with gasoline. With a CO bottle close at hand I slowly dribbled gas onto the manifold. When it found the leak and got sucked into the engine you could hear the idle jump immediately.
In later years when nervous managers prevailed, I'd use gasoline mixed with kerosene. The sudden smoke from the exhaust was not as quick but it worked.
L.J.
"Both the revolutionary and the creative individual are perpetual juveniles. The revolutionary does not grow up because he cannot grow, while the creative individual cannot grow up because he keeps growing." Eric Hoffer
04/22/2010 1:23 PM
Better than gasoline: Use an unlit propane torch and direct the propane around all bolts, gaskets, etc. A speed-up indicates a leak. Heard this from a carb man.
Lehman57
04/22/2010 2:11 AM
Agree with the vacuum leak proposal. Used to use a can of spray carb/choke cleaner and sprayed around the base of carb and/or any vacuum hoses, usually gives fast accurate results .
Good Answers: 58
04/22/2010 7:08 AM
I gave you a GQ for this question. Most likely cause, most carburetors have an external dash pot specifically to handle this kind of situation. The dash pot prevents the throttle from closing rapidly. I suspect yours needs adjusting or replacing. Either way, it's a simple fix.
04/22/2010 8:33 AM
no dash pot, no vacuum leak at gasket.
the lower throttle body shaft and butterfly are the suspect at htis point
Good Answers: 58
04/22/2010 9:14 AM
Congratulations!! You just solved your own problem. Someone stole your dash pot. Seriously, fit a dash pot to the carb, and I suspect your problem will disappear. Your symptoms are why dash pots were fitted in the first place.
04/22/2010 11:30 AM
you are correct on the throttle shaft and body leakage, there are press in bushings available for most sizes or make you own from brass stock and ream to fit after drilling the body for accurate alignment, will be as good as new, the dashpot fitted to later engines is to prevent backfire on rapid decel as the fuel has momentum and continues to flow briefly causing over rich and boom,
Hobbies - Target Shooting - New Member Hobbies - Automotive Performance - New Member
04/22/2010 4:40 PM
It sounds like there could be a burr or carbon build up in the throttle body where the butterfly closes.
04/22/2010 4:59 PM
I would check for worn throttle shaft bushings first if idle is affected by touching the throttle linkage.
Try the mentioned propane test. Turn on the propane but dont light it , with engine running, place the nozzle against the shaft bushings and listen for a rise in idle .
Let us know what you found.
What dosent kill you makes you stronger , lifes a trip so sit back and try to enjoy the nice scenery.
04/23/2010 4:25 PM
your idle jet is clogged
Register to Reply 19 comments
Anonymous Poster (2); Dave K. (1); DaveB (1); flaresideone (4); Laughing Jaguar (1); Lehman57 (1); machine head (1); ozzb (1); peterg7lyq (2); Rex Devantier (1); steele_m_a (1); welderman (2)
