Hi. I happen to have a blue colored compression spring with me from a CVT. The spring sits in the secondary clutch of the CVT and acts both in compression but mainly in twist, in order to provide side force to the belt. One can adjust the range of pre-loads by placing the spring's vertical end in 9 different holes spaced along a half-circle, so you're basically twisting the spring by different amounts after you install the spring with bolts. The spring together with a helix ramp & roller bearing provides the side force to the belt.
I wish to calculate the pre-load on the spring. If I'm thinking about this correctly, it will be a sum of the initial compression and the initial twist when the CVT is not running. Spring constant in compression was estimated to be 70 lbs/in through this online calculator http://www.engineersedge.com/spring_comp_calc_k.htm I don't have any handy spring tester to check twist or compression. Any ideas?
Free length of spring = 3.2"
Outer Diameter of coil = 2.43"
Wire Diameter = 0.160"
Material = Steel
