Previous in Forum: Nickle Metal Hydride Batteries in CoolPix 950   Next in Forum: Were There Giants in the Land?
WPQT Test Piece
04/23/2010 10:07 PM
hi all,
I want to execute wpqt(welder performance qualification test) soon.
this is about test piece for test. we use material 16mo3 and thk 10mm.
I already refer to the asme ix, the size of test piece is 150mm min length and width is 150mm.
could we put the backing plate at back test piece same like aws d1.1 clause 4, qualification figure 4.31?
but this project refer to asme ix
kindly please advice.
Re: WPQT Test Piece
04/25/2010 1:22 AM
WQT shall be fully comply with qualified WPS .
for qualifiying WPS , delection of backing ring is nonessential parameters oin case of SMAW .
you can refer QW-433 sec Ix Alternate F-Numbers for Welde Performance Qualification for welder qualification .
welder qualified with out backing ring is qualified for with backing ring & without backing ring . If welder qualified with backing ring can be only able to do weld with backing only.
you can put backing ring in test piece with considering above mentioned qalification .
with regards
Re: WPQT Test Piece
04/25/2010 10:25 AM
It is always better to qualify welder without backing sothat we can take advantage for with or without backing
kgp
