Previous in Forum: Screw Conveyor Shaft   Next in Forum: Kitchen Hood with Air Speed MUA
What is Tack Plate?
04/25/2010 8:08 AM
For elastomer backed bearings on concrete no tack plate is required.
Is it for assembly purpose?
I am not a home work cheater. I am a translator seeking professional help
Re: what is tack plate?
04/25/2010 11:24 AM
Can't figure that one out.
This may not help.
  1. Slide Bearing Plates: PTFE, 25% Glass Filled, Coated - 8:18amFor field tack welding. 1/2" lip. Loads to 2000 PSI, Temperature: -320°F to +500°F ... of water between the slide bearing plate and the support structure. ...
    www.pipingtech.com/products/ptpcat/slideplate/ptfe.htm - Cached - Similar
  2. [PDF] FCL-SL-005 V3 Fluoroglide Slide Bearing and Pipe Supports.cdr - 8:22amFile Format: PDF/Adobe Acrobat - Quick View
Good Answers: 114
04/25/2010 7:18 PM
I'm not sure of the answer, but thinking aloud, so to speak or write:
In some bearings, particularly bridge bearings, the ends are required to rotate as the bridge deflects, so they bond an elastomeric pad to the underside of the steel plate holding the teflon pad. If this is going on steel, they have to bond another plate under the elastomeric, so it can be tack welded the structure. You wouldn't need this plate if on concrete but I don't know how they would fix it to concrete, I would assume a steel base assembly bolted to the concrete, so that may upset my guess. Sorry
Register to Reply 2 comments
