We have generating units where the existing T90GS 4.2 MW machine will be operated in parallel with new SG-400 machine (11-13 MW) at rated load.. If the SG-400 trips while operating in parallel with existing T90GS 4.2 MW machine, then running plant load will be absorbed by the existing T90GS machine till the load shedding system (PMS system) trips the non-essential loads based on load shedding priority table.The T90GS governor will drive in more fuel into the machine and AVR will boost the voltage till the load shedding system trips the excess load from the system. If there is any mismatch between two events then, there will be cascade tripping of the remaining running generators. In the current set up the existing Rustons (2.3 MW) are run in parallel with T90GS at 2.3 MW against 4.2 MW capacity of the Rustons.In the past, T90GS was run at 4.2 MW with existing Rustons running at 2.3 MW, there were casacade trippings of ruston generators on T90GS's trip due to any reason. The rustons are not able to survive the load impact due to slow response from existing Ruston governor and prolonged delay in existing PMS scheme.
Can this simulation can be tested computer simulation tools like ETAP/SKM etc.? how?
