The car previously had been making a slight squealing noise like antifreeze got on a belt. Immediately after the squealing the temp gauge went straight to hot. turned the car off, checked under the hood and there were no signs of coolant leaking. Pushed on the belt and it had a little too much give and the tensioner didn't seem as tight as it should be. Lifted the front end checked the belt from under the car and checked the tension and grabbed each pulley. The pulley right next to the motor mount turned freely without turning the belt. I'm not sure what the pulley is turning but it looks like the air conditioning compressor pulley by looking at the pictures in the manual. What I don't understand is what would the compressor have to do with the overheating. The belt is still on all of the pulleys but doesn't seem tight enough. I couldn't find any external leaking any where. Could it be the heater core or can the pulley breaking be caused by a bad motor mount?
