Previous in Forum: TIG Welding Procedure for A519 Gr1020   Next in Forum: who can?
Location: pipe line project - KSA ( welding inspector - CSWIP 3.1)
How to Fabricated Miter Elbow
04/27/2010 11:24 AM
Is there is any code for the fabricated elbow ( miter from pipe ).
48" from API 5l Gr B for water pipe line .
I want ask about there is any code states about how many segment to make 90 degree elbow and the center to face distance is it like the ASME B16.9 ( D for short elbow and 1.5D for long elbow) or there is another code for this elbow.
Good Answers: 38
Re: How to Fabricated Miter Elbow
05/09/2010 12:32 PM
Acceptable configurations for mitered elbows are usually descibed in the code of construction for the system.
Although it is not your code of construction, ASME B31.1 & B31.3 contain acceptable configurations.
Normally, a 3, 4 or 5 piece miter is used.
A mitered elbow has much more pressure drop than a smooth wrought elbow
By the way, a single, square joint configuration (a single weld) is NEVER ACCEPTABLE in any code.
Try www.pipingoffice.com....
Oh yeah....pay for the software....don't steal it !!!
03/04/2015 4:00 AM
I have own program to calculate all elbow dimensions.If are you interest contact me.
CR4 ADMIN - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Register to Reply 2 comments
