Previous in Forum: Peppercherries Discoloration   Next in Forum: Passivation in Coating Pan (Pharmaceutical)
EVA Foam Production?
02/13/2007 5:59 AM
Hi to everyone , I would appreciate any help (data,temperatures, process?) about producing EVA foam sheets and molding EVA inside two layer of sheet metal(aluminum and other case galvanized steel).
Thanks for time
Good Answers: 120
Re: EVA Foam Production?
02/14/2007 12:08 AM
A lot of refrigeration companies do this.
They make large reinforced steel outside shells that open into two part. They insert a steel lining on each half, close it up and fill with urethan foam. There are small plastic projection glued to the steel that are expanded where they end up deep in the foam. These prevent the foam from separating from the steel(or aluminum, or ABS sheet plastic).
So if you have a company that does this near you, you can go to them and ask them to make these for you or you can ask to see how they do it. If you do not look like you will enter the refrigerator business, they may let you look at their process.
Per Ardua Ad Astra
02/14/2007 2:42 AM
Thank very much for idea but unfortunately I don't have any company which is in refrigeration biz.I comprehended the general idea but I need some explanation of production process like how to produce EVA , from which components, etc, and from what I 've seen frigo panels are produced from different material(is it true?)
Good Answers: 120
02/14/2007 9:21 AM
start with this search and + and - terms to reduce the answers
http://www.google.ca/search?hl=en&q=%22EVA+foam%22&btnG=Google+Search
Per Ardua Ad Astra
02/14/2007 8:19 PM
Polyurethane materials are 2 part polyemers.Part 1 is a ISOcynate and part 2 is a polyol.
They are mixed at a specific ratio and poured into a tool.
They can produce either Foam or solid materials in a range of hardnesses.
In order to get good consistant foam there is an amout of capital equipment required, such as mixing equipment, foaming tools... etc.
Companies such as Huntsman Polyurethanes manufacture and supply the materials.
02/16/2007 2:38 AM
Thanks A LOT, this was very helpful.
United States - Member - Technical Fields - Education - Hobbies - Hunting - Popular Science - Weaponology -
02/15/2007 9:48 AM
I've recently run across something called a structural insulated panel or SIP. They use a technique similar to what you are talking about. However, it seems that they are using mainly urethane foam or expanded polystyrene. You might search SIP's and get in contact with a manufacturer near by.
David A Goodman
Register to Reply 6 comments
Anonymous Poster (1); aurizon (2); DAG (1); worker (2)
