Previous in Forum: Automatic Belt Conveyor Roller Assembly Machine   Next in Forum: Chatter on Our Okuma LU45
Molding & Casting Difference
05/02/2010 9:48 AM
what is the difference between moulding and casting
Re: Molding & Casting Difference
05/02/2010 11:57 PM
Technologically, today, there is no difference between two words, although molding very broadly represents "non-metallic" material whereas casting represents "metallic" material. The word "casting" has been used for many many years, close to 5000. Both represent melting material to necessary molten state and pouring, under pressure or under gravity, into a pre-designed "mold" which after cooling period solidifies and forms the required shape.
www.maintenancecircle.com
Writer Anand
05/03/2010 4:21 AM
Moulding is the practise of preparing a mould out of sand, wax etc with the help of a wooden or metallic pattern in a foundry. It forms a negative of the shape of the item to be cast. Molten metal is poured into the mould and when solidified, the mould is broken to extract the 'casting' and further processed - heat treatment, machining etc.
Sure you knew this but I couldn't think of a different answer your query could have. Sorry if this isn't what you were looking for.
Register to Reply 2 comments
