Previous in Forum: Heating Under Suspended Wooden Floors   Next in Forum: Safety?
Engine Trouble Mits.4D56
05/02/2010 11:33 AM
i overhauled my mits.4d56,i change all the valve of the cylender and piston ring,after i finish and reasemble.the engine won't start. What should I do?
Re: no subject
05/02/2010 11:43 AM
Don't give us too much information.
Check the fuel delivery system. Can you hear the fuel pump when you turn the ignition key on? Does it run for a few seconds then shut off. (don't crank the motor when you do this)
Is the timing set properly? Do the valves open at the correct piston position and firing sequence?
Battery fully charged?
Good Answers: 53
Re: no subject
05/02/2010 12:08 PM
Does it take too much time and brain to think about a title for your post?
Good Answers: 58
Re: Engine Trouble Mits.4D56
05/02/2010 12:47 PM
I rebuilt a Fiat motor once, replaced a lot of stuff. When done, the motor would not start, good spark, fuel to carb, strong starter. Drug it around the yard with a tractor, no start. Went to my mechanic, said, "I timed it perfectly to cylinder # one, got fuel, etc., what is the problem". "It times to cylinder four, dummy".
Check your specs. It's easy to be 180 degrees out, too.
mike k
05/04/2010 8:00 AM
Overhaul it again. This time do it right.
09/08/2010 2:38 PM
hi...how did you finally solve this problem..cause i do have the exact issue...after replacing a burnt gasket and rephasing my cylinder head...after closing...it wnt start...also looks like its chockin alot of pressure but fuel delivery is okay...
please assist!
Anonymous Poster (1); lyn (1); mike k (1); rakesh_semwal (1); xelamugo (1)
