Previous in Forum: Difference Between Device Equipment and Instrument   Next in Forum: Quality Control/PWHT-P-91
Welding - Check Point Question
05/03/2010 6:40 AM
What is the check point while taking branch connection in welding
Re: Welding - Check Point Question
05/08/2010 12:15 PM
Did you mean inspection check points? Basically when we are taking a branch connection in a run pipe, we are weakening it by making a puncture. So the size of the opening, the size of the reinforcing pad if any, the set-up including angle if any, root weld liquid penetrant/ MP test, the final weld examination and size of weld would be check points as I can see.
05/13/2010 12:05 AM
What's a check point?
"The older I get -The better I was"
Register to Reply 2 comments
