Previous in Forum: Oil Water Separation Using a Mobile Centrifuge   Next in Forum: FlyWheel Energy Storage
Eco Logs From Newspapers
05/04/2010 5:38 AM
Was wondering what, if any, experience anyone has had with recycling old newspapers into eco logs for burning on an open fire in place of traditional wooden logs.
I know that over the winter, we go through a big stack of tree lumps and coal, with a nice load of heat being given off by this combination and any newspapers we have, are used to start the fire off and light the kindling with no further use for them.
I was shown a product which is basically a metal box with holes in it to put hands full of soaked newspaper, then compressed to remove most of the water, let it dry and there you have a brick sized lump of hard paper which can be thrown on the fire in place of a traditional log.
My initial thought was one of what a great way to recycle and get free heat this winter, but I am a little skeptical in that a traditional log will burn and give off heat for a couple of hours and glows nicely for a while after this, but even though the blurb on the product states that the eco logs should give a couple of hours of heat, I can not see this re-constituted log giving a similar amount of energy out.
Now I know that this is effectively free heat as the paper would have been thrown into the recycle bin anyway, but has anyone used these before and if so, what kind of performance can I expect from the eco log when I start my fire again this winter?
I have experimented with soaked cardboard and newspaper and have found that, whilst the cardboard (from packing boxes), should give more energy out due to it being a thicker and denser material, it takes about a week of soaking to be pliable enough the use in the device, whereas the newspaper takes about ½ hour to be mushy enough to use and compresses down much better.
Cheers all
Mike
Aberporth (Wales)
Good Answers: 60
Re: Eco Logs From Newspapers
05/04/2010 2:18 PM
http://www.google.co.uk/search?q=news+papres+into+logs&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-GB:official&client=firefox-a
05/07/2010 9:24 AM
Never done it myself:
  1. Newspaper Log MakerKotulas.com/Paper_Log_Maker Gadget makes logs out of newspapers Free shipping on orders over $25!
  1. How to make newspaper logs for your fire
    - Oct 31, 2008
    You can make fuel for your fire by using newspapers. This instructable shows you how to make a newspaper log in less than two minutes. The video ...
    www.instructables.com/id/Intro_1/ - more videos »
    Get more video results
  2. Making Newspaper Fire Logs
  3. How to Make Newspaper Logs - wikiHow
  4. How to Make Fireplace Logs of Newspaper without Wax | eHow.com
  5. How to Make Logs From Newspapers | eHow.com
  6. Making Newspaper Logs - Associated Content - associatedcontent.comSimilar
  7. Instant Newspaper Logs for Your Fireplace or Wood Stove - No ...
Location: Polyonics, Inc., 867 Rt 12, Westmorelane, NH 03467 603-352-1415
05/07/2010 11:11 AM
Mike
Some years ago there was a device which allowed me tu feed sheets of newspaper into a slot, and by turning a crank (which powered a couple of rollers) it rolled the sheets into logs on a smei-continuous batch basis. I controlled the diameter of the log by how many sheets I fed in, and whether singly or multi-layerd as you'd find in your typical paper. When done, I would use a wire "tie-wrap" to bind the "log". It worked very well. The only problem was disposing of the ash residue. the ash is not as 'well-behaved' as normal wood ask, due to the high level of inorganic fillers in many types of paper. Newsprint worked the best, compared to glossy (i.e. clay coated) papers. I now use a "wood burning" boiler (actually gasification) to get heat value out of the paper and cardboard wastes. Here, too, the high clay content of some papers precludes my desire to burn it, so off to recycle it goes. I'll be interested to see if such a rotary device is still available.
Cheers and good luck Jim
05/07/2010 5:33 PM
Sure:
Not an endorsement. This is one of many available types.
I tried something like this as well, and had pretty much the same experience as you tell us about. This isn't what dolly3900 is talking about, I don't think. Sounds more like 'bricks'. How cleanly do those condensed papers burn?
05/10/2010 5:35 PM
Don't know. Again, I think it will be a function of the clay and fillers the paper manufacturers use, even with bricks. Newsprint is cleanest (along with 'brown paper bags') for lowest ash residue, since it is higher cellulose fiber content and less clay fillers. The glossy papers will be loaded up with inorganic fillers, for texture (smoother) and print quality(due to glossy surface, better character resolution and lower absorption of the ink by the cellulose fibers)...not a hazard to burn..they just don't burn, leaving a LOT more ash than newsprint, papertowels, even corrugated cardboard (if not printed..just natural brown).
thanks for the picture and links...since I now use a woodburning boiler I don't know if I'll try this again...probably will, just to check it out. Heat is heat in New Hampshire in January !!
Thanks
05/13/2010 3:55 AM
Very many thanks to all replys, sounds like there are a few options out there and the one I have seems as good as any.
I have a nice stock of the "logs" drying in the summer sun, made from newsprint and cardboard, going to try a mix of the two as well to see how that goes too.
Will let you know how they go when A) they have dried out enough and B) it is cold enough to light the fire again
Cheers
Mike
Register to Reply 6 comments
dolly3900 (1); Doorman (1); lyn (1); peterg7lyq (1); polyonx (2)
