Previous in Forum: Nozzle Safety With Welding Ribs   Next in Forum: furnace design pressure
Vertical storage tanks
05/07/2010 5:57 AM
In Vertical Storage tanks , what is difference between Drain and Draw off sump ?
What is significance of drawoff sump?
Re: Vertical storage tanks
05/07/2010 9:17 AM
Drain is in the lowest point of tank. Draw off sump is situated at a higher point so that no water is allowed to escape with the fluid that is drawn off.
Good Answers: 58
05/07/2010 2:23 PM
To elaborate on lynlynch's answer, the suction side of the drain pump is usually located in a sump pit 18" to 24" lower than the tank floor. The draw off is usually 12" to 18" above the tank floor.
These measurements are based on a 1 M Barrel tank and 12" suction side piping.
Register to Reply 2 comments
