Previous in Forum: Direct Arc Furnace earthing   Next in Forum: CBCT in Parallel
solar inverter
05/09/2010 11:23 AM
is there an solar inverter for household or industry application? i got idea to design solar inverter,is there any tecnolgy now using in market give information
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
Re: solar inverter
05/09/2010 11:40 AM
Initial cost get high,in general we store dc in battery from solar panel.According to amp-hr rating of battery we get required power for required time. We use dc directly with LED lamp. If you got big panel go ahead.To get 1 amp from a panel is difficult and you have to charge battery.
Good Answers: 119
Re: solar inverter
05/09/2010 12:45 PM
Fairly common item. See link for general info:
http://en.wikipedia.org/wiki/Grid_tie_inverter
Hobbies - Musician - Tube Amps Only Please!
Re: solar inverter
05/09/2010 10:56 PM
Initial cost is high but you may get a rebate from your electric company and you may be able to sell back power you do not use to the electric company. I use Solar cells currently to charge batteries free!
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
hithuanand (1); maveric_manic (1); mjb1962853 (1)
