Previous in Forum: Use of Level Indicating Transmitter   Next in Forum: LabView
Ultra Sonic Flow Transmitter
05/10/2010 11:55 PM
How do you Calibrate a Ultrasonic Flow Transmitter?
Good Answers: 53
Re: Ultra Sonic Flow Transmitter
05/11/2010 2:37 AM
Put a known flow through it and adjust it to agree with the actual flow. Then put a cal sticker on it.
Good Answers: 29
05/11/2010 4:20 PM
Ace is right. His response, however, is just as non-specific as your question. How about some detail.
05/11/2010 10:43 PM
Alternatively , Run with another Volumetric meter in series, in a loop pump around. Or if you have a weigher, collect what ever goes thru the meter into a drum on the weigher, GREAT Care required if you wants high accuracy.
msk
05/12/2010 1:56 AM
Give us some more detail. Is it one of those common ultrasonic doppler velocity probes or a true "flow" meter?
Frankston
05/12/2010 8:29 AM
It depends on if the values derived need to be traceable to some standard. If so, you might need to submit it to a qualified lab or service and let them certify it. If not, contact the manufacturer's tech support and get their input because not all flow meters are the same.
Logan
Ace Boeringa (1); Frankston (1); logan (1); powermass (1); RDGRNR (1)
You might be interested in: Gas Flow Meters, Radio Transmitter ICs, Flow Meters
