Previous in Forum: Management Degree   Next in Forum: Need a Flange Engineered
TWO SPEED 10 HP MOTOR
05/12/2010 8:57 AM
looking for 2 speed 10 hp motor at 208 volts, 3phase for a make up air unit -supplying 12875/4900CFM.
Will appreciate help in finding, Model no of the motor, starter size and wiring diagram.
Thanks
Re: TWO SPEED 10 HP MOTOR
05/12/2010 9:55 AM
You might want to try an engineering search engine like this.
05/13/2010 7:44 AM
thanks for the info.
05/13/2010 4:34 PM
Use a 10hp inverter duty (EE) motor and a VFD. The VFD can be programmed for "preset speeds" switched by a relay/relays. This gives you the flexibility to dial in the exact RPM/CFM you require. With a 2-speed motor you get what you get (typically 1800/1200 RPM). By the time you find a 2-speed 10HP motor (rare these days & expensive) and the starter (also very pricey) you are time and money ahead using the VFD. Welcome to the 21st century!
FYI: I am assuming the makeup air unit has a forward curve fan (most in this size range do). I am not sure you can turn a 12875 CFM blower down to 4900 CFM and be stable. Check the published fan curve. Have fun!
Register to Reply 3 comments
Anonymous Poster (1); RAJ089 (1); redfred (1)
