Previous in Forum: Equivalent or Alternate Material for DIN 2.4813   Next in Forum: Is the "Company Man" always right?
How to Calculate Elbow Center
05/17/2010 8:31 AM
hi,
could someone help me out?
I have to fit 2 90degree 4" sch 80 elbows to a pipe at both ends , such that the total length horizontally is 6000mm.So what should be the length of the pipe and what will be the distance in mm of the elbow center
Good Answers: 61
Re: How to Calculate Elbow Center
05/17/2010 10:30 AM
It is just a simple case of mathematics.
If you are using long radius (LR) elbows: 6000mm minus the center to end of both LR elbows. The center to end of a LR ELL is 1.5 times the nominal diameter.
If you are using short radius (SR) elbows: 6000mm minus the center to end of both SR elbows. The center to end of a SR ELL is 1.0 times the nominal diameter.
Do it once and do it right
