Previous in Forum: Airbags-On & Off Switch?   Next in Forum: Herohonda Splender+
Honda Car Cylinder Misfire Code
05/19/2010 10:54 AM
I have a Honda accord 2000 3.0L v6 engine. All of sudden my car gave 5 out of 6 cylinder misfire code. Should I change plugs and air filter or is there something else I should take care of??
Re: Honda Car Cylinder Misfire Code
05/19/2010 11:36 AM
The big question is surely...
Was the car actually missfiring? Or did the vast array of overcomplicated electronics just 'think' it was missfiring?
that would be the first step in identifying the location of the trouble.
(I could give you a certificate to say it was fine, KrisDelTM do a fine range of certificates for all eventualities.)
Good Answers: 60
05/19/2010 12:35 PM
http://www.google.co.uk/search?q=Honda+accord+2000+3.0L+v6+engine+faults&sourceid=ie7&rls=com.microsoft:en-gb:IE-SearchBox&ie=&oe=&rlz=1I7DKUK_en-GB&redir_esc=&ei=nxL0S4qLDZDy0gTfq5yZDQ
more information needed, as others have said is it actually misfiring ?
check the plugs and see if they are all the same color the spark gap end that is.
while checking see if any plug leads have fallen off.
Good Answers: 60
05/19/2010 12:41 PM
mazda fault codes
http://www.msprotege.com/forum/showthread.php?p=4097464
which code did you get ?
Good Answers: 60
05/19/2010 12:48 PM
what coils have you on your car ?
http://www.thefind.com/cars/info-honda-accord-ignition-coil
is it this type ?
05/19/2010 11:21 PM
thanks for tips guys i will lookup in a day or two nd post here.i haven't checked anyhting till now as i told him to clear codes nd its running ok so far
Register to Reply 6 comments
gsearay19 (1); peterg7lyq (4); user-deleted-1105 (1)
You might be interested in: Bar Code Scanners, Power Plugs, Bar Code Cards
