Hi there,
I have to re-solder the cables from an extension cord of my bike´s intercom headset to a new male (6 pole) mini-DIN plug. I disassembled the enclosure of the plug until exposing a 8mm dia round plastic into which the 6 pins are inserted to. On one side are the male pins and a square larger centering pin. These are to be connected the female plug. On the opposite side, pins get thicker (where I expected to see a hole, to solder the cables into). To my dissapointment the pins on this side were flat, so I supposed the hole was filled with soldering material that had to be heated with the soldering iron having only to slip the bare cable into it. I tried by all means to heat the back of each pin up to do so, but only managed to melt the pins loose from the plastic disc, No need to say how disappointed I am: just supposed I would do this repair in 5 minutes and spent 1 hour only managing to ruin the plug!!!!
The only alternative I thought of was that there must be a small crimping device or a female part to solder the wires to be connected to these f****k pins. Any clue?????
