Previous in Forum: Calculation of Unbalanced 3 Phase Power?   Next in Forum: Mr M
NGR
05/22/2010 2:36 AM
question to ask.
Is it possible to have 3phase, 4wire system with NGR.
India - Member - New Member Engineering Fields - Electrical Engineering - New Member Technical Fields - Technical Writing - New Member
Re: NGR
05/22/2010 10:13 AM
Under 600V system, it is not required to insert NGR. Because-
1. Low earth fault current
2. No sustained earth fault.
3. Easy detection of fault.
4. Easy protection .
Good Answers: 170
Re: NGR
05/23/2010 7:38 AM
Theoratically and Practically possible. But, legally? Depends on which country you are from. If you are from India, it is a strict "no-no". In India, Low Voltage Systems can only be solidly earthed. If you are from US, then, yes! IEEE strongly recommends you to go for NGR Earthing in LV too.
Register to Reply 2 comments
