What is the advantage of using a 24V DC derived internally for local control voltage in an Electric actuator in for a motor operated valve (MOV) instead of 110V AC.. ? what is this voltage used for actually in local controls? thanks in advance
Advantage is , the 24 V DC rated electric actuator will not burn if you use 24 V DC instead of 110 V AC. The voltage should be used accordance with the local control equipments data/rating.
