Previous in Forum: Mitre Bends   Next in Forum: Welding
Composition of Pipe Material A672B70CL32
05/26/2010 2:44 AM
What is the composition of pipe material A672B70CL32 and its properties? Is this ASTM standard material?
Re: Composition of Pipe Material A672B70CL32
05/26/2010 1:20 PM
Yes Its ASTM standard material. You can get your required information from ASMEII Part D (Material properties) and also from CAsti Series (simplified form of ASMEII Part D). Also you can use a software "Key to Steel" property of Key to Steel (now-a-days its called Key to Metals)
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
05/27/2010 3:46 AM
Hi,
A672 is an ASTM specification for welded pipe, so the chemical composition is the same as the base plate used. In the case you mention, B70, the plate must be A515 Gr.70 (plain carbon steel, killed). Nominal composition for thicknesses < 1" are (heat analysis)
C: 0.31 Max
Mn:1,20 Max
P and S Max: 0.035 each
Si: 0.15 ÷ 0.40
For thicker plates, the C content can be a bit higher (0.33 up to 2" and 0.35 for thicker)
Mechanical properties of the plate are:
TS: 70 ÷ 90 ksi
YS: 38 ksi (min)
Elong (2"): 21% min
Weld properties must be at least equal to that of the plate.
Weld must be full length RX examined according to UW-51
Kind regards
Register to Reply 2 comments
