Previous in Forum: power cables 33 &13.8kv termination   Next in Forum: What is Negative Voltge and Negative Current?
distortion
05/29/2010 7:15 AM
dear sir ;
we have an ESG monitors and another monitors in the operation theaters connected to a UPS , There is aproblem wih these monitors some times that the signals appears not as same as the normal signals so the signal be wide .
please help me to avoide this problem
Re: distortion
05/29/2010 9:08 AM
Dear Guest;
CR4 is not a Sir, but a dynamic theam of highly skilled engineers from around the globe, that will make you laugh, maybe pick-up on you, but surely will provide a technically correct answer to almost any question.
I would ask you more details on what you're seeing, for example, when you say that the signal is wide, do you mean that the image on the screen appears wider?.
If so, probably is just someone messing with the aspect ratio setting on your video source, check also for false contacts on you signal wiring and connections.
Provide more details, so we can try and figure it out.
Yahlasit
Re: distortion
05/29/2010 9:22 AM
please hands off from this subject. Operation theater and it matters life. Better you arrange the equipment supplier/manufacturer to solve the problem. ..Are you a doctor?.
Re: distortion
05/29/2010 11:41 AM
I'm afraid that this is another in the long line of CRIMINAL questions. I have no idea what ESG monitor or ESG monitor or UPS or UPS or even signal could be.
Re: distortion
05/29/2010 12:27 PM
Re: distortion
05/30/2010 12:12 AM
Anonymous Poster (2); Baffled (1); lyn (1); redfred (1)
