I want to know wht ll be the calibration range for a dp type level transmitter where medium liquid is process water and the measuring range is 0-5800 mm inside a closed vessel.
specific graviy of capillary fill fluid is silicon dc200 =0.94 and process water 1
the transmitter is installed at the base high side tapping point ( no elevation or supression)
Could u kinldy let me know the formula for calculating the reqd calibration range. The calibration range which is mentioned to me in the datasheet is 0-569mbar. But I am unable to produce this result by my calculation.
thanks.
