Previous in Forum: Automation in Idler Roller Manufacturing   Next in Forum: Parts Sources for Japan-Made 2000 Accord EX 4 Door
19 comments
1990 F350 Duty 5 Speed Manual No Reverse
05/30/2010 8:35 AM
i was makeing a simple u turn went up a drive way went for reverce but was not there .no noise no clonking chatter nothing .can any body let me know whats up .
Re: 1990 f 350 duly 5 speed man no reverce WHY??
05/30/2010 9:38 AM
Compliments of How Stuff Works:
It could be that either the linkage or the collar have failed. If the reverse gear moves on it's shaft and engages while the transmission is in a forward gear you will hear the grinding noise that you seem to expect.
Good Answers: 60
05/30/2010 10:05 AM
Is it manual, Automatic, Car, truck,Bus,Train,roller skates.Space Ship ?
Linkage problems
Gear change cables.
Could be anything, But as i dont know what the vehicle is i cant help
05/30/2010 10:12 AM
What? Did you miss the title? 350 dually 5 speed manual. I corrected some of the spelling.
Good Answers: 97
05/30/2010 10:45 AM
Is this guy still in the driveway?
Could be a differential related problem, or that the shift knob has moved so that the shift pattern on the knob is incorrect?
CRTL-Z
Good Answers: 60
05/30/2010 12:33 PM
So 350 dually is a car make ?
05/30/2010 12:48 PM
Yes, from the information in the title I know that it's a Ford heavy duty 1 ton pickup with dual rear tires and a 5 speed tranny that no longer engages reverse.
Good Answers: 60
05/30/2010 1:05 PM
Sorry missed that for some reason.
must get my eyes checked
05/30/2010 11:13 AM
CR4 Admin Deleted Post #5:
Abuse/Attack:
This post was deleted because it was an attack on another user. Please review the CR4 Site FAQ.
05/30/2010 11:26 AM
CR4 Admin Deleted Post #6:
Irrelevant
This post was deleted because it is related to a deleted post and would otherwise be taken out of context.
05/30/2010 12:55 PM
If you start deleting my posts because they're irrelevant you'll be deleting most of them.
Thanks.
06/04/2010 10:56 AM
"If you start deleting my posts because they're irrelevant you'll be deleting most of them."
Oh, lynlynch... sometimes you just kill me!
Good Answers: 97
05/31/2010 10:20 AM
I would pay to see this reply.
CRTL-Z
Good Answers: 60
05/30/2010 12:36 PM
I have worked out exactly whats wrong with your vehicle.
05/30/2010 12:49 PM
I can't wait to hear this!
Good Answers: 60
05/30/2010 12:57 PM
But since his last response was so nasty i am keeping the answer to my self.
good luck in fnding an answer.
05/30/2010 1:17 PM
The Indy 500 just started. 1st lap, turn two, wrecked already.
Good Answers: 60
05/30/2010 1:54 PM
but i am not vindictive ( well not to much )
this link may be of use,
http://www.ford-trucks.com/forums/946096-im-getting-so-sick-of-this-damn-truck.html
Re: 1990 f 350 duly 5 speed man no reverse WHY??
05/30/2010 5:07 PM
I figure I'll take my chances and try to help this poor soul. There is a gear that must engage the reverse idler in order to obtain reverse. With the limited amount of information we have to work with it sounds like a shifting fork isn't doing its job. Do all of the other gears work ok? I believe the low(1st) and reverse shifting fork move the same gear. The tip of the shift stick slides into whichever of three pockets 1st-rev, 2nd-3rd, and 4th-5th. if it feels like it is working in low but not reverse or vise versa the locking bolt on the shift rail that locks the fork to the rail may have come loose or out of position.
Sometimes all that's required is to remove the floorboard and take out the bolts that hold the shift tower to the trans. Just looking in there may show the problem. I believe 1st & reverse are obtained by moving the shift stick to the left. That means the shift rail under the shift tower on the extreme right is the rail and fork in question. Its not a difficult job to do ,but you may not feel like trying it. Most important......do not allow any dirt to enter the trans. If you are still awake I'll close now.
Please let us know if we were any help since you're still laughing from the other great replies.
h
Re: 1990 F350 Duty 5 Speed Manual No Reverse
05/31/2010 3:22 AM
It is a Ford what did you expect it to act like someone designed it who cared if it would last and work when you needed it too ?
They need you to bring it in to the shop more often it is designed to fail and need repair .
Think about it oxygen sensors on a heavey duty truck ? for what reason they use a ton of fuel so adding junk only makes them use more , see they are desinged to cost you more all the way around.
Register to Reply 19 comments
Anonymous Poster (1); dadw5boys (1); Doorman (1); lyn (7); peterg7lyq (6); rondog (1); Unredundant (2)
You might be interested in: Noise Standards, RF Noise Meters
