Previous in Forum: otor Starting Reactor - 3.3KV, 1800HP   Next in Forum: why neutral earthing is required for DG.
8 comments
Grid integration of Wind turbine- Matlab simulink Modelling
06/04/2010 7:06 AM
Hello friends
I am quite new to matlab Simulink, I have started designing of Grid integration of wind turbine
I have used 1. Wind turbine block (have input of speed,pitch angle, generator speed & torque as o/p)
2.the torque is used as input to drive the asynchronous block(squirrel cage, in pu)
3. which consist of two step up/step down t/f
4. 30 km PI section Transmission line ,
5. I considered grid as programmable voltage source
so i have one fundamental question how the parameters for all the components are set ?
based on what manner the parameters should be calculated?
Just dont reply like read basic machines book blah blah blah...
just reply with concrete method from where i have to start calculate the parameters?
if there any pdf or books for this help me out.
If there is any other open source package to do this simulation just let me know?
Good Answers: 183
Re: Grid integration of Wind turbine- Matlab simulink Modelling
06/04/2010 8:39 AM
Do you simulate a wind mill or a fan ?
06/04/2010 11:37 AM
if you dont know about the problem just ignore
Good Answers: 183
06/04/2010 1:29 PM
In stead of being arrogant and unpolite you could better ask yourself why such a question was considered as necessary.
When you come to ask for help you should NOT despise comments the risk is that you will not get any answer to your questions.
Do not assume other people are stupid and ignorant and you as the only clever around.
If this is the case then why ask stupid people for help?
Anyway from me you do not get any support although I could give you some.
06/05/2010 1:08 AM
You sound like my physics professor in university (that was 42 years ago) . If you need help there is something called "courtesy" which you should learn. No ill feelings !! good luck. Just the advice of an old man.
06/05/2010 2:11 AM
İ like this - starts of with the salutation 'Hello Friends' and then insults the first guy to ask a question. For someone that has no idea what they are doing and fishing for someone else to tell them how! Go to the books buddy!
India - Member - New Member
Good Answers: 164
06/05/2010 4:47 AM
One assumes you already have tried all the examples available at Mathworks? Just in case, here is a link .. windturbine
06/05/2010 7:12 AM
Please send the contact details of your boss. I will send the details with my consultation fee.
10/03/2010 4:12 PM
Hello Iam doing some researches in the same area. send me and overview of what you are doing. at moda14.smartgrid@gmail.com Thanks
angelo (1); Anonymous Poster (3); kvsridhar (1); nick name (2); russ123 (1)
