Previous in Forum: Training Material for Jet Mills   Next in Forum: Metallic Composition
Corrosion Factor for SA516 Gr 70
06/05/2010 2:36 AM
What is the corrosion factor for SA516 Gr 70?
5
Re: Corrosion Factor for SA516 Gr 70
06/05/2010 11:08 PM
• You have to submit a lot of data because the corrosion depends on:
- Type of Fluid
- Fluid Concentration
- Fluid Temperature
- Type of Material where the fluid flow in
• See the following CR4 Threads:
- Corrosion Allowances for Equipment and Pipes
- Re: Pipe schedule calculation
Reply Good Answer (Score 5)
Good Answers: 243
06/05/2010 11:34 PM
Nice informative reply as usual Abdel!
milo
06/06/2010 1:03 PM
Oh . . Thank you Milo, and many thanks qaqcpipeman,
Milo is the best, since he have a score of 180 "Good Answers" where I have only 157.
Good Answers: 243
06/06/2010 5:02 PM
My good Friend Abdel.
I do not remember who was on here first, you or I.
I do know that the Good answerr procedure started about a year or so ago.
Regardless, You have a higher yield of good answers to total answers.
I have more answers in many fields.
Your answers are the gold standard in steel and piping.
I seldom have much to add if You have posted before me...
You, Kwetz, QAQCPIPEMAN, Gremlin, SteveS, and a few others have provided deeper answers in my field from time to time.
Best regards.
Milo
06/07/2010 7:01 AM
Not one of should be singled, out my friend.
Hopefully, we can all learn and teach here.
And, as for me the good votes I give are for a job well done.
I respect those of you who can present ideas, fact, and questions that further my knowledge. And, the off topics I give have as much fervor, certain things should not be posted here, politics and religion show an extreme lack of professionalism.
And, as some of you have seen, I will reply back at times for blatant disregard for the membership ethos as a whole, regardless my philosophy.
06/06/2010 12:58 PM
Thanks Abdel, I constantly learn and get reminded from your posts.
Abdel Halim Galala (2); Milo (2); qaqcpipeman (2)
