Previous in Forum: 3 Phases to Single Phase Conversion   Next in Forum: US Standard - Indoor Earth Pits
How to Design Generator For 1kw Wind Turbine
06/08/2010 1:41 AM
how to perform the the design n simulation of wind turbine generator which the cut in speed in about 1.0 m/s and rted wind speed is about 3 m/s and the cut off speed is about 20m/s. i have not any idea how to do that..
Good Answers: 145
Re: how to design generator for 1kw wind turbine
06/08/2010 2:00 AM
If you do a bit of a search on here you'll find plenty to keep you amused.
I'll leave this link as a primer for you.
http://cr4.globalspec.com/thread/46550/Walks-in-Storms-VAWT-Project
If you dig through the OP's various threads you should get the information you need
06/08/2010 2:07 AM
thanks for your comment..its useful for me
India - Member - New Member
Good Answers: 164
06/08/2010 2:41 AM
Maybe this will interest you too ....
http://www.otherpower.com/wood103.pdf
Re: How to Design Generator For 1kw Wind Turbine
06/09/2010 1:50 AM
What is the basis of the mentioned figures, "cut in speed about 1.0 m/s", "rated wind speed about 3 m/s" & "cut off speed about 20 m/s". Is this just an arbitrary figure or you have some details with you?
Thanks and regards
Ashok Toshniwal, Bangalore, India.
06/09/2010 1:59 AM
As the available power in wind at 1 m/s is nothing and even at 3 m/s is not worth going after İ expect these are dart board numbers. 5 m/s is a practical minimum really.
06/09/2010 2:44 AM
Russ, Actually I wanted the originator of this querry, to answer to my question!!!
Reply Score 1 for Off Topic
06/09/2010 2:23 AM
I have a great idea, used an alternator of RV (motor home) this kind of alternator output is 120 vots, and can use a litle gear box to increase the RPM, need a battery 12Volts, like a Bike, is only to excite the alternator, and the blades, building of half of PVC pipe of 6 inches, put in a shaft with square pipe and this is a easy disign of wind power
Anonymous Poster (2); ashoktoshniwal (2); kvsridhar (1); russ123 (1); Tobugrynbak (1)
