I have to do modification in 13.8kV, 60Hz system. The scenario is a 13.8kV, 60Hz, 3-core, 240sq-mm, Cu, XLPE cable feeder (length=2.2km) coming from main substaion (protected by SF6 CB and AEG PS451) is feeding an 1MVA transformer (protected by VCB and siemens 7SJ602). Now we are planning construct new residential buildings. For that, we are planning to terminate the cable at new panel (will act as incoming) and taking two outgoings, one for the new building and other for the existing building. The take off point will be at somewhat near to the joint of cable.
Please suggest the new incoming and outgoing isolation types considering proper protection. Will new incoming be just the bus riser panel (no isolation required) or load break switch or CB and the outgoing panel for the existing building that no any panel is required or only isolator will be enough or CB?
