Previous in Forum: Metallic Composition   Next in Forum: what is corrosion
Best Environmental Protective Coating Over Silver
06/08/2010 10:13 AM
What is the best environmental, protective coating over silver?
I'm busy with an electric and magnetic field sensor to measure harmonics strengths etc, have vacuum metalized onto glass fiber reinforced plastic housing.
Unfortunately used silver instead of Aluminum.
In anycase it's few microns so hopefully H will penetrate.
E sensor plates outside box, H sensor coil inside with the microprocessor.
Do you know what I can paint over the silver, needs to be UV and weather (salt fog) resistant and adhere.
Hoping to prevent scratches as the silver layer comes off easily.
Good Answers: 141
Re: Best Environmental Protective Coating Over Silver
06/08/2010 9:15 PM
Normally you shouldn't put a coating over a coating that has no adequate adhesion onto the layer.
The new coating will ruin the first one. Did you consider electrolytic coating - Gold and Platinum are the toppers and need no further protection.
Plenty of room here
06/09/2010 2:27 AM
Yes, thanks, I nickle plated an ABS box as an alternative (stronger, but still investigating properties). Apparently one cannot electroplate onto FRP (Fibre reineforced plastic).
I agree the base coat to surface is more the issue, but was hoping to overcoat with some sort of epoxy paint to prevent scratches caused by handling and installation.
06/08/2010 10:44 PM
If you've got the capability to vacuum metalize, then the normal top coats should be adequate. From memory GLYPOXAN was used for Al, Ag, Au in a previous location.
Your basecoat adhesion though is of concern. Your vacuum metalizing (equipment) suppliers will be able to recommend a compatible base coat and top coat.
By the way, if the layer is "a few microns" thick, then that's a prety thick vacuum metalise.
If it's only to measure H and not to be optical grade, why not just let it oxidise?
06/09/2010 2:38 AM
Thanks, it's outsourced, I'll ask them if a topcoat like GLYPOXAN can be used in future, sounds good. Sorry, regarding the thickness-yes it's probably much thinner (thou's mils microns, I'm not used to the scales) anyhow I'll ask them how thick they do/can go, for interest. I wasn't planning to coat, just found it scratches too easily.
Good Answers: 56
06/09/2010 9:09 AM
Broadband mirrors and those used by astronomers in the optical spectrum typically have a thin coating of SiO to prevent the aluminum from tarnishing. Since aluminum is relatively soft material, the SiO helps protect from scratches as well.
If your assembly can withstand the vacuum of a deposition chamber, you might do well to have them hard coated using a sputtering method and SiO. That your coating is silver rather than aluminum should not make a difference.
To do this properly, however, ideally there should be no outgassing from any of the components
Good luck
Laughing Jaguar
"Both the revolutionary and the creative individual are perpetual juveniles. The revolutionary does not grow up because he cannot grow, while the creative individual cannot grow up because he keeps growing." Eric Hoffer
06/10/2010 10:41 AM
Thanks, yes, Alu would have had a similar issue, please consider this discussion ended
Have decided to go with nickle electroplating onto ABS instead and hope the Nickle coating provides enough UV protection.
Register to Reply 6 comments
dvmdsc (1); Hilt (3); Just an Engineer (1); Laughing Jaguar (1)
You might be interested in: Protective Packaging, Coating Services
