Previous in Forum: Diesel Day Tank   Next in Forum: Disimilar capacity pumps connected to common header
India - Member - Mechanical Engineer Engineering Fields - Petroleum Engineering - Mechanical Engineer
ASME - Heat Treatment
06/10/2010 3:09 AM
Does ASME Sec. VIII DIv.1 say anythin abt the minimum thickness for heat treatment if yes the clause plz?????
Varun Passi
Pathfinder Tags: ASME heat treatment
Engineering Fields - Piping Design Engineering - New Member
Re: ASME - Heat Treatment
06/10/2010 12:19 PM
About which material you are taking about?
See Table UCS-56 against the P.No. of your material. For P.No. 1 materials, the minimum thickness requiring PWHT is 38mm. You may see for others in the table mentioned.
Regards,
Ashfaq Anwer
http://thepetrostreet.com
06/11/2010 12:36 PM
the material is ASTM A516 Gr.70 n i've gone through the code if the minimum thickness is 38mm then y does the table UCS-56 say the heat treatment for thickness upto 2inch also????
Varun Passi
06/11/2010 2:31 PM
Upto 2 inches means any thickness from 38 mm onwards to 50 mm.
See Note 2 under table UCS-56 for more information.
Regards,
Ashfaq Anwer
06/12/2010 2:49 PM
Suppose it is a lethal service, you have heat treat for any thickness, Is't it? Then what is minimum thickness that can be heat treated?
RK
06/13/2010 4:09 AM
That's depend upon the design specifications issue by the designer. Code explicitly mentions "The exemptions provided in Table UCS-56 or Table UCS-56.1 are not permitted when postweld heat treatment is a service requirement"
Regards,
Ashfaq Anwer
ashfaqanwer (3); brkmech (1); varunpassi (1)
