Previous in Forum: Drawing a House Plan   Next in Forum: Single Lane Private Bridge
ATV
06/10/2010 9:58 AM
why would my yamaha blaster have a knock when i just rebuilt the top end
Good Answers: 60
Re: ATV
06/10/2010 1:37 PM
have you left anything inside.
are the valves set correctly.
now youve improved the compression the little or big ends would be under more presure when fuel ignites.
Good Answers: 29
Re: ATV
06/10/2010 3:50 PM
What parts were replaced in your rebuild?
Did you measure the piston to cylinder wall clearance?
The specs I found for the model you called out (Blaster) say it's a two stroke. There's not much to replace save piston and rings. The most common reason for the knock; to me, would be the possibility that a piston ring was broken during reassembly and went unnoticed.
If the wrist pin wasn't replaced and a new piston installed there may be excessive play there that could cause a knock. The last thing I can think of is excessive clearance between cylinder and piston.
Not to be a jerk, but you should have posted this in Automotive. There are more people lurking there that are more interested in engines and mechanicing.
Si vis pacem, para bellum
Re: ATV
06/10/2010 7:42 PM
1. Did it have the knock before? Is that why you rebuilt it?
2. Is this your first rebuild?
3. Did you align the rings properly?
4. Not enough information to give any real advice.
5. We don't read minds.
Good Answers: 60
Re: ATV
06/10/2010 11:18 PM
and the standard issue crystal ball wont work because they have been recalled because they look to far into the future if you accelerate or push them.
my crystal ball was made at toyota,
Reply Off Topic (Score 6)
lyn (1); peterg7lyq (2); PMoon (1)
