Previous in Forum: Gun Metal   Next in Forum: Supplier for X65 Coupons
Material Equivalent
06/11/2010 1:12 AM
Dear All, I am in urgent need of the equivalent standards of the following materials for chemical composition and traceability.Pls help me.
Cast Iron 1.4729
Cast Iron 1.474
Refractory Alocast H 40
Flat Iron C45K
Cast Iron EN GJL250
Cast Iron EN GJL250+1.5% CR
Shaft S355J2G3
Shaft S355J2G3+C
Pipe S355J2H
Steel Plate S355MC
M16 Hex Bolt DIN 916
17 Washer DIN 7349
It is far better to be associated with a few who are right than with the mob which is wrong,because right is always the winner in the end.
Re: Material Equivalent
06/11/2010 9:20 AM
Engineering Fields - Piping Design Engineering - New Member
06/14/2010 2:51 AM
I have mentioned exact Chemical Composition and approximate equivalents of few materials you mentioned.
Shaft S355J2G3 | Chemical composition: Carbon 0.200 Manganese 1.600 Silicon 0.550 Phosphorus 0.035 Sulfur 0.035 Equivalent: Grade:50 [345] Standard: ASTM A572 or Grade: III Standard: ASTM A714
Pipe S355J2H | Chemical Composition: Carbon 0.220 Manganese 1.600 Silicon 0.550 Phosphorus 0.035 Sulfur 0.035 Equivalent: Grade: III ASTM A714
Steel Plate S355MC | Chemical Compositon: Carbon 0.120 Manganese 1.500 Silicon 0.500 Phosphorus 0.025 Sulfur 0.020 Aluminum 0.0150 Columbium (Niobium) 0.090 Titanium 0.150 Vanadium 0.200 Nb + V + Ti 0.220 Equivalent:/ FeE355TM ISO 6930 International or FeE355TM UNI 8890 Italy
Regards,
Ashfaq Anwer
http://thepetrostreet.com
Egypt - Member - New Member Engineering Fields - Mechanical Engineering - New Member
06/14/2010 4:49 AM
the folowing data for some materials
for equivalent standards pls download this file http://www.4shared.com/file/z5qqFwxJ/New_Folder__3_.html
note that materials No 1.429 & 1.4740 arn't cast iron,
Material Number
1.4729
Steel group
Stainless and heat-resisting steels
Symbol
GX40CrSi13
Standards
?NORM EN 10295 (10/2002)
Heat resistant steel castings
Range of application
Heat-resisting steel castings:
Hearth-plates, door frames and other similar hearth parts.
Suitable welding filler materials 1.4733, 1.4829.
Material Number
1.4740
Steel group
Alloy special steels: Heat resistant steels with < 2,5% Ni
Symbol
GX40CrSi17
Standards
DIN EN 10295 (01/2003)
International conformity
EN 10295 (2002)
Replaces
DIN 17465 (08/1993)
Superheater parts, pipe clamps, carrying handles, grates.
Suitable welding filler materials 1.4015, 1.4502, 1.4829.
Material Number
1.1191
Steel group
Non alloy special sructural steels: Structural steels with average C < 0,50%
Symbol
C45E; Ck 45 †
Standards
DIN EN 10083-1 (10/1996)
Quenched and tempered steels. Special steels.
EN 10083-1+A1 (1996)
Replaces
DIN 17200 (03/1988) (03/1987)
DIN EN 10132-3 (05/2000)
Cold-rolled narrow steel strip for heat-treatment. Steels for quenching and tempering.
Replaces
EN 10132-3 (2000)
DIN EN 10250-2 (12/1999)
Open die steel forgings for general engineering purposes. Non-alloy quality and special steels.
Replaces
EN 10250-2 (1999)
DIN EN 10269 (11/1999)
Steels and nickel alloys for fasteners with specified elevated and/or low temperatures properties.
DIN EN 10277-5 (10/1999)
Bright steel products. Steels for quenching and tempering.
DIN EN 10297-1 (06/2003)
Seamless circular steel tubes for mechanical and general engineering purposes. Non-alloy and alloy steel tubes. Non-alloyed high-quality steels
Seamless circular steel tubes for mechanical and general engineering purposes. Non-alloy and alloy steel tubes. Alloyed quality steels
DIN EN 10305-1 (02/2003)
Steel tubes for precision applications. Seamless cold drawn tubes.
DIN SEW 550 (08/1976)
Steels for larger forgings.
Heat-treatable steels:
Automobile- and motor construction, mech. engineering
High-temperature constructional steels:
Bolts and nuts, resistant to elevated temperatures up to 400 °C
These steels can also be supplied with a sulphur-content of 0,020-0,040%. Then e.g. C22E = C22R, resp. Ck22 = Cm 22 or receive the letter S (e.g. 32Cr2 = 32CrS2). Number of material in brackets. The mechanical properties are identical.
Material Number
1.0570
Steel group
Non alloy quality steels: Steels with average C > 0,25 < 0,55 % or Rm > 500 < 700 N/mm²
Symbol
S355J2G3; St 52-3; St 52-3 G; (S355J2G3+CR)
Standards
DIN 1623-2 (02/1986)
Steel flat products. Cold reduced sheet and strip. General structural steels.
ISO 4997 (1999)
DIN 5512-1 (05/1997)
Materials for rail vehicles. Structural steels and structural steels with improved atmospheric corrosion resistance, hot rolled.
DIN 5512-2 (05/1997)
Materials for rail vehicles. Unalloyed steels for cold rolled flat products up to 3 mm thickness.
DIN 5515 (11/1978)
Steel sections, bars and flat products of non-alloyed steels and general structural steels. Summary for rail vehicles.
Replaced by
E DIN 5515 (10/1999)
DIN EN 10025 (03/1994)
Hot rolled products of non-alloy structural steels.
Replaced by
EN 10025 (1993); ISO 630 (1995); ISO 4995 (2001); ISO/FDIS 6316 (2000); ISO 13976 (1998)
Way of deoxydation: Fully killed steel containing nitrogen binding elements in sufficient amounts to bind the nitrogen (p.e. Al >= 0,02%).
With special cold workability: 1.0569; S355J2G3C
Former designation DIN 17100: St 52-3 N
Former designation of steels with special working properties,
Cold flanging: 1.0573; QSt 52-3 N
Cold drawing: 1.0597; ZSt 52-3 N
Cold roll forming: 1.0575; KSt 52-3 N
Material Number
1.0569
Steel group
Symbol
S355J2G3C; QSt 52-3
Standards
Replaces
DIN 17100 (01/1980)
DIN EN 10277-2 (10/1999)
Bright steel products. Steels for general engineering purposes.
Material Number
1.0576
Steel group
Symbol
S355J2H; RoSt 52-3
Standards
DIN 1626 (10/1984)
Welded circular unalloyed steel tubes subject to special requirements.
ISO 9330-1 (1990)
Replaces
DIN 1626-1 (01/1965); DIN 1626-3 (01/1965)
DIN EN 10210-1 (09/1994)
Hot finished structural hollow sections. Non-alloy steels
DIN EN 10219-1 (11/1997)
Cold formed welded structural hollow sections. Fine grain steels
Material Number
1.0976
Steel group
Alloy quality steels: Steels for various applications
Symbol
S355MC
Standards
DIN EN 10149-2 (11/1995)
Hot rolled flat products made of high yield strength steels for cold forming. Delivery conditions for thermomechanical rolled steels.
EN 10149-2 (1995); ISO 5951 (2001); ISO 6930-1 (2001)
Fine grained steels for cold pressing:
Longitudinal beams
Construction of frames
Parts for cold pressing
Cold rolled sections
No God but Allah
06/14/2010 8:16 PM
Thank you ashfaqanwer and engabdou1 for your help.May Allah bless u.
07/21/2010 2:28 AM
Dear All, I am in urgent need of the equivalent standards of the following materials for chemical composition and traceability.Pls help me. i : Pipe s355J2G3 ii : Pipe s355K2G3 iii : Pipe S355G1+N iv : Bar s355J0
07/28/2010 9:14 AM
Only one I found:
S355J2G3: Grade-50 [345] ASTM A572 or Grade-III ASTM A714
Regards,
Ashfaq Anwer
Register to Reply 6 comments
ashfaqanwer (2); doshayu78 (1); engabdou1 (1); inconel (1); lyn (1)
