Previous in Forum: Who Sells TANK007 Flashlight?   Next in Forum: McBain's New Near-Infrared Inspection System Is Improving Chip Yields in Malaysi
Copper Wire & Coax Design
06/11/2010 10:11 AM
We have a New Wire Design which increases the surface area of the wire while reducing the heat dissipation ability & decreases resistance.
This is a positive new way of extending the wire capacities in the use of Electrical, Communications, Coils, Electromagnetic Gauss without adding wires or increasing gauges. This Electrical wire can be used in all gauges including Power Grids & Hydroelectric.
The Design will give you about at least a 30-40% more surface area in the commonly used length of wire. A smaller gauge will suffice as compared to today's standards giving unlimited applications.
A Simulation will bear out the benefits of this design thru R&D.
Costs of production should be minimal. An additional die added into an existing wire drawing machine will produce the desired effect while saving material costs.
The same opportunity for a second Patent to go with the First Patent is now
pending also .This Coax cable acts as a shield & ground without the costs & weight. This printed lattice network is on the outer cable unlike the metal lattice.
We are looking for a Partnership to develop this design.
Sincerely,
jamesleppert@netzero.net James Leppert
(301) 387-4344 USA
redmonjr@msn.com William Redmon
(719) 395-0622 USA
The U.S. Patent was Publically Disclosed on February 9th, 2010.
Patent Number D 609477
( USPTO) US 29/347,085
China Patent Number DIM 091388
Drawing # PAF 10505295
Also posted in: also posted in Communications & Electronics
Re: Copper Wire & Coax Design
08/20/2010 12:59 AM
Reducing heat dissipation is bad.
Increasing surface area can be bad.
Only the Hi-Fi audio world would buy such a thing.
Lower cost and weight sileding is a good thing.
Explain it with numbers and someone might be interested.
