Previous in Forum: Supplier for X65 Coupons   Next in Forum: Re-Circulation Rate and Over-All Heat in Falling Film Evaporator for Evaporation
What Happens in Reaction?
06/12/2010 5:51 AM
In addition of sodium thio sulphate +nitricacid
what happen
Re: what happen
06/12/2010 7:12 AM
Good Answers: 60
Re: What Happens in Reaction?
06/14/2010 8:06 AM
A Reaction
Good Answers: 60
06/15/2010 3:59 PM
The exact same question is to be found on this link
http://www.thestudentroom.co.uk/showthread.php?t=378508
And taken from another site.
The reaction between nitric acid and sodium thiosulphate
Nitric acid reacts with sodium thiosulphate solution according to the following equation:
2H+(aq) + S2O3
2-(aq) % S(s) + H2O(l) + SO2(aq)
The sulphur dioxide remains in solution and the insoluble sulphur causes the solution to become opaque. The initial
rate of reaction can be determined by measuring the time taken for enough sulphur to be produced that it obscures
a cross drawn on a piece of paper placed below the reaction vessel.
Requirements
1.0M sodium thiosulphate solution
0.1M nitric acid
distilled water
3 burettes and funnels
150cm3 beaker
test tube
stopclock
Safety
Lab coats and safety glasses
should be worn
Procedure
a) Using a burette, add 2.0cm3 of sodium thiosulphate solution to the
beaker
b) Using another burette, add 8.0cm3 of distilled water to the same beaker
c) Using a third burette, add 10.0cm3 of nitric acid to a test tube
d) Start a stopclock as you add the nitric acid from the test tube to the
beaker
e) Swirl the beaker gently to mix the contents and place over the cross
f) Note the time taken for the cross to be obscured by the precipitate of
sulphur
g) Repeat for different quantities of each solution as shown in the results
table
Results
Volume (cm3)
Experiment
1.0M Na2S2O3 0.1M HNO3 H2O
Time, t, for cross
to be obscured (s)
Rate of reaction,
1/t (s-1)
1 2.0 10.0 8.0
2 4.0 10.0 6.0
3 6.0 10.0 4.0
4 8.0 10.0 2.0
5 10.0 10.0 0.0
6 6.0 6.0 8.0
7 6.0 8.0 6.0
8 (same as 3) 6.0 10.0 4.0
9 6.0 12.0 2.0
10 6.0 14.0 0.0
Analysis
1. Plot a graph of t-1 on the vertical axis against the volume of sodium thiosulphate solution (which is directly
proportional to [S2O3
2-] as the total volume is 20cm3 in each case) on the horizontal axis for experiment 1-5
and then plot another graph of rate of reaction against the volume of nitric acid (which is directly proportional
to [H+]) for experiments 6-10.
2. Inspect your graphs and use them to deduce, with explanations,
a) the order of reaction with respect to thiosulphate ions
b) the order of reaction with respect to H+
c) the overall order of the reaction
3. Write an expression for the rate equation for this reaction.
4. What does this suggest about the rate-determining step of the reaction?
5. Comment on the accuracy of your experiment and the reliability of your conclusi
