Previous in Forum: Petrol and Diesel Cycles   Next in Forum: Mold texture
Chimney Design
02/21/2007 11:30 AM
I like to design chimney for a 2 no boiler. One is 10 tph and second is 15 tph . Both are fired with Furnace oil ( heavy oil).
Some body help me how to arrive 4 diametre and height. What is the weight of chimney. How to connect two exhaust in a one chimney
Engineering Fields - Piping Design Engineering - New Member Technical Fields - Architecture - New Member
Re: Chimney Design
02/22/2007 12:43 AM
You need to have more inputs like your location,windspeed in your location,soilconditions of your location,composition of your boiler exhaust with special focus on sox, temperature of exhaust etc then refaer any strctural design book for design of chimney.
best of luck
Run silent run deep
United States - Member - Engineering Consultant Popular Science - Evolution - Understanding
Re: Chimney Design
02/22/2007 1:27 AM
In addition, he better check all applicable codes and regulations if he doesn't want to have to tear it down after he builds it.
Greg
Re: Chimney Design
02/22/2007 2:34 AM
Things to consider: 1) Smoke stacks must be constructed according to codes because insurance companies require it. 2) Use prefabricated double wall stainless-steel stacks, otherwise fabricating a stack and insulating it is not really cost effective, until you get into large boilers requiring breeching, etc. 3) Unless boilers are fired simulaneously, use separate stacks, otherwise you may not have enough draft to carry out the products of combustion without condensation taking place in the stack. 4) The manufacturer of the boilers can give you the required size of the stack(s). 5) Stack must be minimum of 2 feet above the roof.
Hope this helps.......
Re: Chimney Design
02/22/2007 2:37 AM
I don't mean to be discouraging but if you need to ask these questions don't attempt this project. There's a lot more to flues than meets the eye!
An engineer is a man who can do for five bob what any bloody fool can do for a quid (Neville Shute)
Re: Chimney Design
02/23/2007 6:19 PM
CR-4 = Conference Room (this is where we are now)
UCR = University Class Room. (this is where you should be)
Anybody home?
Wangito.
Never trade luck for skill.
Technical Fields - Education - New Member Technical Fields - Technical Writing - New Member
Re: Chimney Design
02/24/2007 8:45 AM
Two sources to one chimney?!
I have seen the effect in one "experimental oil refinery".
After the second source started, the chimney became an outer space rocket driven by exploded gases+dust
It became a "civil engineers' joke" for the observers
crm (1); Greg G (1); nutwood (1); OLD F**T (1); southern123 (1); wangito (1)
