Previous in Forum: Electricity from Lightning   Next in Forum: Power Electronics Project Title
Electric Winch
06/12/2010 8:39 PM
Using an electric endlees winch with a 10,000 lb.capacity, my question here is how long can I run the winch pulling 1,000lbs continuosly? The winch would be placed under the top gear and will be pulling down.
Re: Retired
06/12/2010 8:54 PM
  1. Milemarker Winches, winch accessories and safe Winching The high power consumption and low duty cycles are the obvious disadvantages of the electric winch. The electric winches are not able to perform in extreme ...
    www.uncleroys.com/faqs.php
  2. Winch solenoid power consumption for switching? - Yahoo! UK ... on a wallbright or equivalent winch 12 volt solenoid how much is the ... Usually between .5 and 1.5 amps for a 100 amp model. Since you'd need a little bigger
    uk.answers.yahoo.com/question/index?qid... - United Kingdom
  3. [PDF] HOW TO DESIGN A BIG NEW WINCH HOW TO DESIGN
    For the winch, this defines the power consumption of the drive system. Real World Conditions. To establish the final requirements of winch performance, ...
    www.markeymachinery.com/.../Pac_Maritime0707_designingwinch.pdf -
  4. Concrete Hoist - MG Construction Machinery. Description, Fixed Hoist or Builder Hoist with Winch Machine. Bucket Capacity, 1000 kg. Winch Capacity, 2.5 Tons. Power Consumption, 10 hp for electric ...
    www.mgmachines.com/concrete-hoist.html
  5. power winch exporter - power winch manufacturers, exporters ...power consumption of electric motors gluing applicator electric winch press vacuum pump manual tools for grooving ... Manufacturer : Sino Machinery Co.,Ltd ...
    www.ec21.com/kp-power-winch/ -
  6. Crystal Solar - Anchor winches Power 12V 800W Max load 3
Good Answers: 120
Re: Electric Winch
06/13/2010 11:19 PM
you will have to inspect the duty cycle of the winch motor, the type of motor, and the general capability of the winch and it's lubrication system.
Some of these small winches will run electrically for a an indefinite time at 10% of their rated load. That means the coild will not fry.
BUT, if it is a brush type series motor, it is not capable of long term operation. An industrial induction motor, with good bearings, can run at 10% load for years, with lube inspections every month or so. The reduction gear train....is it up to industrial spec, does it run in oil? or is it a consumer bumper mounted thing made in china.
The chain/cable. The way you speak, this cable will be a loop that will go round a spindle. This is in effect bending a piece of metal back and forth...in time it will break, steel strand by steel strand until it breaks and baby falls, cradle and all.
So it will need a weekly inspection and should be a stainless steel cable.
Per Ardua Ad Astra
Re: Electric Winch
06/14/2010 6:11 PM
Thank you I'm pleased with your answer.If I need more info whom can I speak to ?
Good Answers: 120
Re: Electric Winch
06/14/2010 6:28 PM
Well, I am in Toronto, Canada. I would suggest you speak with an industrial winch supplier, to see what is his closest match to your job. Bear in mind that it may cost quite a bit. Cheap $200 winches will probably fail in a week in your 100% duty cycle.
I suggest you tell us what you are doing this for. Then we can apply some experience to the task, and we may well find a cheaper/better way.
Per Ardua Ad Astra
Register to Reply 4 comments
aurizon (2); joemauliz (1); lyn (1)
