Previous in Forum: Mechanical Vibration   Next in Forum: Project on Power Systems
Neutral Earthing for Multiple Transformers
06/13/2010 12:11 AM
Can multiple transformers used with parallel UPS system have common neutral earthing?
Re: Neutral Earthing for Multiple Transformers
06/13/2010 5:01 PM
Yes, I think that the best way for paralleling UPSs insulation transformer including the by-pass transformer is to use a neutral bar where you connect all the neutrals.
Cilmo.
06/14/2010 12:02 AM
i worried about the neutral currents between the ups and the bypass supply. Also can these neutral currents for a close circulating path between the UPS's.
06/13/2010 11:00 PM
Jeesh,, I should hope so!
Good Answers: 170
06/14/2010 10:18 AM
Each UPS with an Isolation Transformer is a Separately Derived Source and as per NEC (National Electric Code), each sepaartely derived source must be earthed separetly only.
Register to Reply 4 comments
Anonymous Poster (1); baxterm (1); electricalexpert65 (1); vinod tomar (1)
